The following error appears when trying to start the application:
flatpak run rest.insomnia.Insomnia
[2:0906/181916.988807:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
A JavaScript error occurred in the main process
Uncaught Exception:
Error: /usr/lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /run/user/1000/app/rest.insomnia.Insomnia/.org.chromium.Chromium.QvzDCH)
at process.func [as dlopen] (node:electron/js2c/asar_bundle:2:1822)
at Module._extensions..node (node:internal/modules/cjs/loader:1354:18)
at Object.func [as .node] (node:electron/js2c/asar_bundle:2:2049)
at Module.load (node:internal/modules/cjs/loader:1124:32)
at Module._load (node:internal/modules/cjs/loader:965:12)
at f._load (node:electron/js2c/asar_bundle:2:13330)
at Module.require (node:internal/modules/cjs/loader:1148:19)
at require (node:internal/modules/cjs/helpers:110:18)
at Object.<anonymous> (/app/main/resources/app.asar/node_modules/@getinsomnia/node-libcurl/dist/Easy.js:5:18)
at Module._compile (node:internal/modules/cjs/loader:1269:14)
Gtk-Message: 18:19:18.175: Failed to load module "xapp-gtk3-module"
[2:0906/181918.238706:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[2:0906/181918.238739:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
