Is there a way to download a flatpak from flathub standalone?
While debugging problems with a flatpak application, I wondered whether there is a way to manually download the current version (or another specific version) of a flatpak package to filesystem, other than installing it. Ideally, I’d like just a snapshot, like you would download a .deb file for Debian/Ubuntu or .rpm file for Fedora/Suse.
I am aware of How to download software with all its dependencies offline in a direct and easy way, however that doesn’t work for me:
$ flatpak create-usb /tmp/flatpak-test-for-signal org.signal.Signal
error: Remote ‘flathub’ does not have a collection ID set, which is required for P2P distribution of ‘app/org.signal.Signal/x86_64/stable’.
I have no clue what that means.
Just follow the link to the USB Drives documentation - it explains how & which collection ID has to be set.
Thank you! (see the docs here)
Can this be done with a specific version? with `flatpak update –commit=[hash]`, I could do that on my machine. But how about the `create-usb` command, where this is not possible?
I think create-usb works with what is locally available. You’ll have to flatpak update –commit=[hash] first if you want a specific version.
