Hi! I’ve written a script to manage my flatpak packages in Nushell:
#!/usr/bin/env nu
export-env {
$env.GUM_CHOOSE_SELECTED_FOREGROUND = '#64d633'
while true {
try {
let response = (gum choose --no-show-help
--header='What would you like to do?'
uninstall exit)
match $response {
uninstall => {
try {
let applications_to_uninstall = (flatpak list --app --columns=application |
gum choose --no-limit |
str join |
split row "\n")
flatpak uninstall ...$applications_to_uninstall -y
exit => {
exit
} catch {
exit
While no matter how I tried to launch it:
flatpak run org.kde.konsole -e /home/emilygraceseville7cf/Documents/programming/mine/nu/application-manager.nu
it failed to be executed properly - the window with it got closed almost instantly after it’s lauch. It worth mentioning that when my script is attempted to be lauched via konsole installed via apt everything works as expected.
Current Konsole flatpak permissions are:
[Context]
shared=network;ipc;
sockets=x11;wayland;session-bus;system-bus;fallback-x11;
devices=dri;all;
features=devel;bluetooth;canbus;per-app-dev-shm;
filesystems=home;host-etc;host-os;xdg-config/kdeglobals:ro;host;
[Session Bus Policy]
com.canonical.AppMenu.Registrar=talk
org.kde.kconfig.notify=talk
org.kde.KGlobalSettings=talk
org.freedesktop.Flatpak=talk
org.kde.kdeconnect=talk
Konsole version: 25.04.1
The original post is here.
