Issue with Shortwave After Upgrading to Linux Mint 22.1
Hello,
I have been using Shortwave without any issues, but after upgrading to Linux Mint 22.1, I encountered a problem. When launching Shortwave, the application briefly appears and then crashes. I see the following error in the logs:
*shortwave:2): Adwaita-WARNING *: 22:32:39.177: GtkStack 0x64ff2610afe0 exceeds SwApplicationWindow width: requested 652 px, 640 px available
*(shortwave:2): Gdk-WARNING *: 22:32:39.633: The program ‘shortwave’ received an X Window System error.
This probably reflects a bug in the program.
The error was ‘BadRegion (invalid Region parameter)’.
  • (Details: serial 1068 error_code 140 request_code 138 (XFIXES) minor_code 11)*
  • (Note to programmers: normally, X errors are reported asynchronously;*
  • that is, you will receive the error a while after causing it.*
  • To debug your program, run it with the GDK_SYNCHRONIZE environment*
  • variable to change this behavior. You can then get a meaningful*
  • backtrace from your debugger if you break on the gdk_x_error() function.)*
Qualsiasi aiuto o suggerimento sarebbe molto apprezzato!
Shortwave is directly maintained by upstream, you should report it to Sign in · GitLab or GitHub · Where software is built
