Hello Everyone,
I’m a member of the Darling team and I am currently assessing how viable it would be to run Darling as a Flatpak app.
Right now I am trying to build libfuse
. From what I observed, it seems like libfuse
builds just fine, but Darling is not able to detect the built library for some reason (It uses FindPkgConfig.cmake
to check for the ‘fuse’ library).
-- Checking for module 'fuse'
-- Package 'fuse', required by 'virtual:world', not found
CMake Error at /usr/share/cmake-3.22/Modules/FindPkgConfig.cmake:603 (message):
A required package was not found
Call Stack (most recent call first):
/usr/share/cmake-3.22/Modules/FindPkgConfig.cmake:825 (_pkg_check_modules_internal)
src/external/darling-dmg/CMakeLists.txt:121 (pkg_check_modules)
I looked at the build directory and noticed that the compiled FUSE files are stored in the files
directory. The var/lib
folder seems to be empty. Maybe this is the reason why Darling is not detecting the compiled FUSE libraries?
$ tree build-dir/
build-dir/
├── files
│ ├── bin
│ │ └── fusermount3
│ ├── etc
│ │ ├── fuse.conf
│ │ └── udev
│ │ └── rules.d
│ │ └── 99-fuse3.rules
│ ├── include
│ │ └── fuse3
│ │ ├── cuse_lowlevel.h
│ │ ├── fuse_common.h
│ │ ├── fuse.h
│ │ ├── fuse_log.h
│ │ ├── fuse_lowlevel.h
│ │ └── fuse_opt.h
│ ├── lib
│ │ ├── debug
│ │ │ ├── bin
│ │ │ │ └── fusermount3.debug
│ │ │ ├── lib
│ │ │ │ └── libfuse3.so.3.10.5.debug
│ │ │ ├── sbin
│ │ │ │ └── mount.fuse3.debug
│ │ │ └── source
│ │ │ └── fuse
│ │ │ ├── _flatpak_build
│ │ │ ├── include
│ │ │ │ ├── cuse_lowlevel.h
│ │ │ │ ├── fuse_common.h
│ │ │ │ ├── fuse.h
│ │ │ │ ├── fuse_kernel.h
│ │ │ │ ├── fuse_log.h
│ │ │ │ ├── fuse_lowlevel.h
│ │ │ │ └── fuse_opt.h
│ │ │ ├── lib
│ │ │ │ ├── buffer.c
│ │ │ │ ├── cuse_lowlevel.c
│ │ │ │ ├── fuse.c
│ │ │ │ ├── fuse_i.h
│ │ │ │ ├── fuse_log.c
│ │ │ │ ├── fuse_loop.c
│ │ │ │ ├── fuse_loop_mt.c
│ │ │ │ ├── fuse_lowlevel.c
│ │ │ │ ├── fuse_opt.c
│ │ │ │ ├── fuse_signals.c
│ │ │ │ ├── helper.c
│ │ │ │ ├── modules
│ │ │ │ │ ├── iconv.c
│ │ │ │ │ └── subdir.c
│ │ │ │ ├── mount.c
│ │ │ │ ├── mount_util.c
│ │ │ │ └── mount_util.h
│ │ │ └── util
│ │ │ ├── fusermount.c
│ │ │ └── mount.fuse.c
│ │ ├── libfuse3.so -> libfuse3.so.3
│ │ ├── libfuse3.so.3 -> libfuse3.so.3.10.5
│ │ ├── libfuse3.so.3.10.5
│ │ └── pkgconfig
│ │ └── fuse3.pc
│ ├── sbin
│ │ └── mount.fuse3
│ └── share
│ └── man
│ ├── man1
│ │ └── fusermount3.1
│ └── man8
│ └── mount.fuse3.8
├── metadata
└── var
├── lib
├── run -> /run
└── tmp
Below is how I set the yml files. These files are also hosted on GitHub.
org.darlinghq.darling.yml
app-id: org.darlinghq.Darling
runtime-version: '21.08'
command: darling shell
- name: darling
buildsystem: cmake
builddir: true
- modules/fuse.yml
- type: git
url: https://github.com/darlinghq/darling.git
commit: c30e22f13ea61d867d76adc2914ec8352cac66be
modules/fuse.yml
buildsystem: meson
config-opts:
- -Dudevrulesdir=/app/etc/udev/rules.d
- -Duseroot=false
- type: archive
url: https://github.com/libfuse/libfuse/releases/download/fuse-3.10.5/fuse-3.10.5.tar.xz
sha256: b2e283485d47404ac896dd0bb7f7ba81e1470838e677e45f659804c3a3b69666
