Hi There,
First time user of Kodi Flatpack. Long time Kodi user.
Just wondered if advancedsettings.xml is able to be used with Kodi FlatPack.
I have installed the advancedsettings.xml file I have used in previous installs into the userdata folder and it will not connect to my mysql database.
Thanks in advance
Iril
Hey, it should work fine. I would assume, that you’ve put the file into the wrong folder, as flatpaks tend to have slightly different folder setups.
Did you put it into ~/.var/app/tv.kodi.Kodi/data/userdata
Hey razzeee,
Thanks for the reply.
The PC is running ubuntu 22.04, logs in as the “kodi” user automatically. So I installed the advancedsettings.xml in this folder : /home/kodi/.var/app/tv.kodi.Kodi/data/userdata
It does not see the kodi library.
Thanks
Martin
Check/paste your kodi.log
Got it…
The network is not up and running before it tries to reach the Database Server.
The log is full of
Unable to open database: kodi_music83 [2002](Can't connect to server on '192.168.0.1' (101))
Need to add a pause before starting up flatpak / kodi.
Thanks for your time
Martin
