Hi community,
for a view hours I’m trying now to make an installation via flatpak. My initial goal is to install mellowplayer. This is all supposed to run on a raspberry pi and no matter what I or search for, I simply do not get the results back at it should have.
I followed this:
https://flatpak.org/setup/Raspberry%20Pi%20OS/
All good until now. No matter what I try to install, I always get this: "error: Nothing matches "
It stays like this, even after reboot. Adding the repo (again) does not give any errors.
Everywhere I look it says, that “com.gitlab.ColinDuquesnoy.MellowPlayer” is the correct address.
The same goes for other apps. Just picked one from the list:
Sudo only removes the warning.
Anybody, any idea? Thanks.
Kind regards
ver0n
