Hi
can I migrate all the data and password saved on the remmina app on the Debian repository to the remmina flathub version?
thanks
Andrea
Probably, you would have to figure out where remmina stores their user settings etc and copy it over. So install both apps, then copy that data over to the similar org.remmina.Remmina folder
