Minecraft pe apk
I downloaded the minecraft apk and open the minecraft flathub pe I can’t import the file, how can I do?
You have to log in (google) into the launcher, then the launcher downloads the game for you.
Why you shouldn’t import an apk:
  • To prevent piracy, you will get an license error on newer versions of the mcpelauncher. If you refuse to login with your google account owning the game.
  • You cannot use modded apks with this launcher, most of them fails to extract. You saw the error?
  • You have to import the correct version of the apk, an apk which works on your phone is unlikly to work on a PC. (arm is not x86_64)
