Missing pidgin in Flathub
When searching for Pidgin in the site returns the image of Pidgin and when you click on it the page says,
" App Not Found
No app with the ID im.pidgin.Pidgin was found on Flathub. Try searching for the app using the search bar above."
Yet, Pidgin is available in the repo and can be installed from the command line. Bug?
Looks like a flathub.org issue, seems to work on the beta site Pidgin | Flathub
I filed an issue so the admins can look at it.
Flathub—An app store and build service for Linux is back
