sonny
November 15, 2021, 6:09pm
#1
Hello,
My app is missing screenshots - I thought it was a temporary issue with Flathub when publishing the initial version but the problem persists after publishing a new version - I have no idea why.
GNOME Software displays the screenshot properly when I use a local remote to preview.
https://flathub.org/apps/details/re.sonny.Junction
Any idea?
It might be a problem with the aspect ratio and resizing, read here:
opened 09:13PM - 16 May 18 UTC
closed 01:10AM - 31 May 18 UTC
@jgarciao I was told to ping you. The issue is just what the tittle says... Gnom… e software shows the preview thumbnails, but it also lacks the "big" screenshots. Flathub doesn't show neither one
sonny
December 13, 2021, 9:02pm
#3
@fedelibre thanks but it looks unrelated
I took some time to investigate - looks like downloading the screenshots from Github fails with SSL handshake failed
here is what the build reports
Mirroring screenshots from appdata
e]2;flatpak-builder: Mirroring screenshotsaFB: Running: flatpak build --die-with-parent --nofilesystem=host --filesystem=/srv/buildbot/worker/build-x86_64/build/builddir --filesystem=/srv/buildbot/worker/build-x86_64/build/.flatpak-builder/screenshots-cache --share=network /srv/buildbot/worker/build-x86_64/build/builddir appstream-util mirror-screenshots /srv/buildbot/worker/build-x86_64/build/builddir/files/share/app-info/xmls/re.sonny.Junction.xml.gz https://dl.flathub.org/repo/screenshots/re.sonny.Junction-stable /srv/buildbot/worker/build-x86_64/build/.flatpak-builder/screenshots-cache /srv/buildbot/worker/build-x86_64/build/builddir/screenshots/re.sonny.Junction-stable
re.sonny.Junction: Downloading https://raw.githubusercontent.com/sonnyp/Junction/main/data/screenshot.png
re.sonny.Junction: Failed to download https://raw.githubusercontent.com/sonnyp/Junction/main/data/screenshot.png: Downloading failed: SSL handshake failed
re.sonny.Junction: Downloading https://raw.githubusercontent.com/sonnyp/Junction/main/data/screenshot-file.png
re.sonny.Junction: Failed to download https://raw.githubusercontent.com/sonnyp/Junction/main/data/screenshot-file.png: Downloading failed: SSL handshake failed
re.sonny.Junction: Downloading https://raw.githubusercontent.com/sonnyp/Junction/main/data/screenshot-shortcuts.png
re.sonny.Junction: Failed to download https://raw.githubusercontent.com/sonnyp/Junction/main/data/screenshot-shortcuts.png: Downloading failed: SSL handshake failed
Saved screenshots in /srv/buildbot/worker/build-x86_64/build/builddir/screenshots
https://flathub.org/builds/#/builders/48/builds/8402/steps/6/logs/stdio
It’s quite strange since one of my other app which does exactly the same thing doesn’t fail
Mirroring screenshotsaFB: Running: flatpak build --die-with-parent --nofilesystem=host --filesystem=/srv/buildbot/worker/build-x86_64-5/build/builddir --filesystem=/srv/buildbot/worker/build-x86_64-5/build/.flatpak-builder/screenshots-cache --share=network /srv/buildbot/worker/build-x86_64-5/build/builddir appstream-util mirror-screenshots /srv/buildbot/worker/build-x86_64-5/build/builddir/files/share/app-info/xmls/re.sonny.Commit.xml.gz https://dl.flathub.org/repo/screenshots/re.sonny.Commit-stable /srv/buildbot/worker/build-x86_64-5/build/.flatpak-builder/screenshots-cache /srv/buildbot/worker/build-x86_64-5/build/builddir/screenshots/re.sonny.Commit-stable
re.sonny.Commit: Downloading https://raw.githubusercontent.com/sonnyp/Commit/main/data/screenshot-light.png
re.sonny.Commit: Saved to cache /srv/buildbot/worker/build-x86_64-5/build/.flatpak-builder/screenshots-cache/re.sonny.Commit-screenshot-light.png
re.sonny.Commit: Downloading https://raw.githubusercontent.com/sonnyp/Commit/main/data/emoji.png
re.sonny.Commit: Saved to cache /srv/buildbot/worker/build-x86_64-5/build/.flatpak-builder/screenshots-cache/re.sonny.Commit-emoji.png
re.sonny.Commit: Downloading https://raw.githubusercontent.com/sonnyp/Commit/main/data/screenshot-dark.png
re.sonny.Commit: Saved to cache /srv/buildbot/worker/build-x86_64-5/build/.flatpak-builder/screenshots-cache/re.sonny.Commit-screenshot-dark.png
re.sonny.Commit: Downloading https://raw.githubusercontent.com/sonnyp/Commit/main/data/welcome-light.png
re.sonny.Commit: Saved to cache /srv/buildbot/worker/build-x86_64-5/build/.flatpak-builder/screenshots-cache/re.sonny.Commit-welcome-light.png
re.sonny.Commit: Downloading https://raw.githubusercontent.com/sonnyp/Commit/main/data/welcome-dark.png
re.sonny.Commit: Saved to cache /srv/buildbot/worker/build-x86_64-5/build/.flatpak-builder/screenshots-cache/re.sonny.Commit-welcome-dark.png
Saved screenshots in /srv/buildbot/worker/build-x86_64-5/build/builddir/screenshots
https://flathub.org/builds/#/builders/35/builds/8435/steps/6/logs/stdio
It sounds like GitHub is rate limiting you or something. But it’s strange it’s giving you an SSL error.
sonny
December 14, 2021, 3:46pm
#5
Not sure what makes you think rate limiting is at play here?
Anyway - it looks like an issue on flathub’s infrastructure and I can’t do much about it - would be great if someone who can had a look.
sonny
December 16, 2021, 11:40am
#6
I try hosting the screenshots somewhere else - same result
e]2;flatpak-builder: Mirroring screenshotsaFB: Running: flatpak build --die-with-parent --nofilesystem=host --filesystem=/srv/buildbot/worker/build-x86_64-3/build/builddir --filesystem=/srv/buildbot/worker/build-x86_64-3/build/.flatpak-builder/screenshots-cache --share=network /srv/buildbot/worker/build-x86_64-3/build/builddir appstream-util mirror-screenshots /srv/buildbot/worker/build-x86_64-3/build/builddir/files/share/app-info/xmls/re.sonny.Junction.xml.gz https://dl.flathub.org/repo/screenshots/re.sonny.Junction-test /srv/buildbot/worker/build-x86_64-3/build/.flatpak-builder/screenshots-cache /srv/buildbot/worker/build-x86_64-3/build/builddir/screenshots/re.sonny.Junction-test
re.sonny.Junction: Downloading https://junction.sonny.re/screenshot.png
re.sonny.Junction: Failed to download https://junction.sonny.re/screenshot.png: Downloading failed: SSL handshake failed
re.sonny.Junction: Downloading https://junction.sonny.re/screenshot-file.png
re.sonny.Junction: Failed to download https://junction.sonny.re/screenshot-file.png: Downloading failed: SSL handshake failed
re.sonny.Junction: Downloading https://junction.sonny.re/screenshot-shortcuts.png
re.sonny.Junction: Failed to download https://junction.sonny.re/screenshot-shortcuts.png: Downloading failed: SSL handshake failed
Saved screenshots in /srv/buildbot/worker/build-x86_64-3/build/builddir/screenshots
https://flathub.org/builds/#/builders/39/builds/8525/steps/6/logs/stdio
sonny
December 16, 2021, 11:47am
#7
Removing GLib from the flatpak manifest fixes the SSL handhsake issue.
https://github.com/flathub/re.sonny.Junction/pull/3/commits/5dd95eb3e8c62e548be1622ea40b818d5c72dc43
I’m a bit confused how or why it is affecting flatpak-builder.
sonny
December 16, 2021, 2:43pm
#8
Problem solved
See
committed 02:34PM - 16 Dec 21 UTC
On flathub.org/builds - appstream-util mirror screenshots runs in the sandbox w… here glib fails to load glib-networking. Bundling glib-networking fixes the problem.
https://discourse.flathub.org/t/missing-screenshots/1852/6
There is a WIP PR that moves this outside of the sandbox
https://github.com/flatpak/flatpak-builder/pull/418
and
https://matrix.to/#/!RfXaBjokqHAbzZrgHz:matrix.org/$aGMJI2eKuQ9d1tHmsEJWR2Sr3aTHKTztBT_oNGRFaew?via=matrix.org&via=gnome.org
