Mpv 0.38.0 build fails - how to access /run/build/mpv/_flatpak_build/meson-logs/meson-log.txt
Hi, I’ve been maintaining io.mpv.Mpv for last many years because I love mpv player for its minimalism and performance. The Indian govt. has blocked access to Videolan.org, so I can’t download the sources from videolan required to build and test mpv locally. I managed with flathub build bot to build and release, but can’t access logs like meson-log.txt which are required to report build issues at mpv.
A full log can be found at /run/build/mpv/_flatpak_build/meson-logs/meson-log.txt
at flathub buildbot I couldn’t find the access to meson-log.txt
could anyone help, please?
You might be more lucky with these mirrors:
https://videolan.mirror.ba/
https://videolan.c3sl.ufpr.br/
The download links would have a bit different path (no pub/videolan)
