I am working on build a flatpak for the open source software BOINC. It is used by scientists to distribute computational workloads to the computers of volunteers. I think I got the entire build process down right, but I can’t seem to actually run the app due to a missing file error.
I’m guessing this is an easy fix, but I have googled and chatgptd to no avail. Any help would be greatly appreciated.
In my build directory I have a file org.thesciencecommons.boinc.yml with the contents:
app-id: org.thesciencecommons.boinc
runtime-version: '23.08'
runtime: org.freedesktop.Platform.GL
runtime: org.freedesktop.Platform.GL.nvidia
runtime: org.freedesktop.Platform.GL.mesa-git
runtime: org.freedesktop.Platform.GL.default
runtime: org.freedesktop.Platform.VAAPI.Intel
command: boincmgr
# X11 + XShm access
- --share=ipc
- --socket=fallback-x11
# Wayland access
- --socket=wayland
# Needs to talk to the network:
- --share=network
# Needs to save files locally
#- --filesystem=xdg-documents
#- --metadata=X-DConf=migrate-path=/org/gnome/dictionary/
# GPU acceleration
- --device=dri
##### freeglut and libXmu needed for projects that display graphics
##### https://boinc.berkeley.edu/trac/wiki/GraphicsApi#api
- name: libnotify
buildsystem: meson
- type: git
url: https://gitlab.gnome.org/GNOME/libnotify.git
config-opts:
- -Dtests=false
- -Dman=false
- -Dgtk_doc=false
- -Ddocbook_docs=disabled
- name: glu
buildsystem: meson
- type: archive
url: https://archive.mesa3d.org/glu/glu-9.0.3.tar.xz
sha256: bd43fe12f374b1192eb15fe20e45ff456b9bc26ab57f0eee919f96ca0f8a330f
cleanup:
- /include
- /lib/*.a
- /lib/*.la
- /lib/pkgconfig
- name: freeglut
buildsystem: cmake-ninja
- type: archive
url: https://github.com/FreeGLUTProject/freeglut/releases/download/v3.4.0/freeglut-3.4.0.tar.gz
sha256: 3c0bcb915d9b180a97edaebd011b7a1de54583a838644dcd42bb0ea0c6f3eaec
cleanup:
- /include
- name: libXmu
- type: archive
url: https://www.x.org/releases/individual/lib/libXmu-1.1.4.tar.gz
sha256: 3091d711cdc1d8ea0f545a13b90d1464c3c3ab64778fd121f0d789b277a80289
cleanup:
- /include
- /share
- name: wxWidgets
- type: git
url: https://github.com/wxWidgets/wxWidgets.git
tag: v3.2.2.1
commit: a812fffda3fe686c94e24bff27e8effd96e4de64
cleanup:
- /bin
- /include
- /share
- /lib/wx/include
- name: boinc
buildsystem: autotools
make-install-args:
- DESTDIR=${FLATPAK_DEST}
- prefix=
- exec_prefix=
- type: git
url: https://github.com/BOINC/boinc.git
### Patch to change 2 prefs - workaround the broken simple GUI and exit the boinc client when boincmgr closes
- type: file
path: org.thesciencecommons.boinc.metainfo.xml
# - type: patch
# path: change-application-defaults.patch
- type: shell
commands:
- ./_autosetup
config-opts:
- --disable-server
- --disable-fcgi
post-install:
### Overwrite BOINCDIR or else it will warn that it can't find gui_rpc_auth.cfg
- sed -i 's:#BOINCDIR=/var/lib/boinc:BOINCDIR=/:' ${FLATPAK_DEST}/etc/boinc-client.conf
- install -Dm644 clientgui/res/boinc.svg ${FLATPAK_DEST}/share/icons/hicolor/scalable/apps/${FLATPAK_ID}.svg
- install -Dm644 clientgui/res/boinc.desktop ${FLATPAK_DEST}/share/applications/${FLATPAK_ID}.desktop
- install -Dm644 org.thesciencecommons.boinc.metainfo.xml ${FLATPAK_DEST}/share/metainfo/${FLATPAK_ID}.metainfo.xml
- desktop-file-edit --remove-key=Path ${FLATPAK_DEST}/share/applications/${FLATPAK_ID}.desktop
- desktop-file-edit --set-icon=${FLATPAK_ID} ${FLATPAK_DEST}/share/applications/${FLATPAK_ID}.desktop
cleanup:
- /usr
This builds without any significant errors with flatpak-builder --user --install --force-clean build-dir org.thesciencecommons.boinc.yml however when I try a flatpak run org.thesciencecommons.boinc I get the error bwrap: execvp /bin/boincmgr: No such file or directory
I have gotten a shell within the flatpak with flatpak run --command=sh --devel org.thesciencecommons.boinc and have verified that there is a file at /app/bin/boincmgr as expected. And I can successfully run it from within the shell, but I can’t get it to run with flatpak run I have also tried specifying absolute and relative paths in my flatpak run command with no change in results.
Why can’t flatpak see this binary?
