Hello,
I have been trying to package SciDAVis for a while.
Here is my progress on it.
I have also contact SciDAVis dev, but not much progress so far.
https://sourceforge.net/p/scidavis/discussion/708155/thread/a41121371c/
I have an issue PyQt is not found when building SciDAVis.
ModuleNotFoundError: No module named 'PyQt5'
Traceback (most recent call last): File "<string>", line 1, in <module> ModuleNotFoundError: No module named 'PyQt5' CMake Error at /usr/share/cmake-3.19/Modules/FindPackageHandleStandardArgs.cmake:218 (message): Could NOT find PyQt (missing: PyQt_FLAGS) (found version "") Call Stack (most recent call first): /usr/share/cmake-3.19/Modules/FindPackageHandleStandardArgs.cmake:582 (_FPHSA_FAILURE_MESSAGE) cmake/FindPyQt.cmake:55 (find_package_handle_standard_args) CMakeLists.txt:103 (find_package)
-- Configuring incomplete, errors occurred!
See also "/run/build/scidavis/CMakeFiles/CMakeOutput.log". Error: module scidavis: Child process exited with code 1
I include PyQt and SIP and dependencies. But SciDAVis cannot find it, I assume that it is looking at wrong place or I botch PyQt installation.
- name: sip
- python3 configure.py
--bindir=/app/bin
--destdir=/app/lib/python3/dist-packages
--incdir=/app/include/python3
--sipdir=/app/share/sip
--stubsdir=/app/lib/python3/dist-packages
--sip-module=PyQt5.sip
- make -j $FLATPAK_BUILDER_N_JOBS
- make install
cleanup:
- /bin
- type: archive
url: https://www.riverbankcomputing.com/static/Downloads/sip/4.19.25/sip-4.19.25.tar.gz
sha256: b39d93e937647807bac23579edbff25fe46d16213f708370072574ab1f1b4211
- name: pyqt5
--confirm-license
--sip-incdir=/app/include/python3
--bindir=/app/bin
--designer-plugindir=/app/lib/plugins/designer
--qml-plugindir=/app/lib/plugins/PyQt5
--stubsdir=/app/lib/python3/dist-packages/PyQt5
--disable=QtDesigner
--disable=QtOpenGL
--disable=QtBluetooth
- make install
- type: archive
url: https://files.pythonhosted.org/packages/6e/86/d715e71771cece0e060f2ebab20f3ded067b08a0927dfb3143530cae8098/PyQt5-5.15.3.tar.gz
sha256: 965ba50e7029b37f218a54ace24e87c77db3e5a9f0b83baeb21fb57b4154b838
Please help.
Thank you.
