Hello,
I use LMDE6 and am looking for a tool like SmartSniff for Windows. Unfortunately I have not found anything.
Does anyone have tips?
Hello,
You can try Wireshark, but not the Flathub version
Too bad there’s no such tool for Linux. ![]()
Actually, I didn’t want to use Wireshark because it is too extensive for my purposes.
Why not the Flathub version? Which one do you recommend?
Wireshark is the only graphical tool that I know, but I’m not that deep into network sniffing, so there may be a hidden gem that fits your needs. Mist of the tools I heard of are command line programs.
Due to limitations of the Flatpak Sandbox, Wireshark is not able to capture traffic.
Install it from the Repos of your Distro.
