OARS None When Missing
The standard says:
In case the <content_rating/> tag is empty (no <content_attribute/> is present), it is assumed that the component was checked for age ratings and no age restrictions apply.
But I left out Nudity and Violence and the application data says “No information provided” instead of that there is not any.
Which app are you checking? I might have a look.
Probably related to the OARS version. Would you implement the following changes?
I commented on the codeberg pull request also, but I am wondering if I use KDE as well as GNOME, if that version is an issue?
In this case, you can set them to the none. Like the following.
Actually, there is nothing wrong with your application. I assumed something was wrong and tried to fix it. It’s just wording.
From the Bazaar app
From the GNOME Software
I merged your second pull request, but it may be a while before I submit a new version to test the change.
