Hello friends, tanks for the opportunity, i try install obs studio, but…
Is there a solution to my problem?
my system:
System: Host: hall Kernel: 4.9.0-12-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: Cinnamon 4.2.4 wm: muffin dm: LightDM Distro: LMDE 3 Cindy
base: Debian 9.3 stretch
Machine: Type: Desktop Mobo: ASUSTeK model: M5A97 LE R2.0 v: Rev 1.xx serial:
UEFI: American Megatrends v: 2202 date: 12/12/2013
CPU: Topology: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 42138
Speed: 1400 MHz min/max: 1400/3500 MHz Core speeds (MHz): 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400
Graphics: Device-1: AMD Curacao PRO [Radeon R7 370 / R9 270/370 OEM] vendor: PC Partner Limited
driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6811
Display: x11 server: X.Org 1.19.2 driver: ati,radeon unloaded: fbdev,modesetting,vesa
resolution: 1440x900~60Hz
OpenGL: renderer: Gallium 0.4 on AMD PITCAIRN (DRM 2.49.0 / 4.9.0-12-amd64 LLVM 3.9.1)
v: 4.3 Mesa 13.0.6 compat-v: 3.0 direct render: Yes
Audio: Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1002:4383
Device-2: AMD Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aab0
Sound Server: ALSA v: k4.9.0-12-amd64
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK P8 series driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
Drives: Local Storage: total: 298.09 GiB used: 26.50 GiB (8.9%)
ID-1: /dev/sda vendor: Samsung model: HM321HI size: 298.09 GiB speed: 3.0 Gb/s
serial:
Partition: ID-1: / size: 48.07 GiB used: 26.50 GiB (55.1%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 2.47 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 18.0 C mobo: N/A gpu: radeon temp: 33 C
Fan Speeds (RPM): cpu: 0
Repos: Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: {//}packages.linuxmint.com} cindy main upstream import backport #id:linuxmint_main
2: deb https: {//}deb.debian.org/debian stretch main contrib non-free}
3: deb https: {//}deb.debian.org/debian stretch-updates main contrib non-free}
4: deb http: {//}security.debian.org stretch/updates main contrib non-free}
5: deb http: {//}www}.deb-multimedia.org stretch main non-free}
Info: Processes: 210 Uptime: 20m Memory: 7.70 GiB used: 2.52 GiB (32.7%) Init: systemd v: 232
runlevel: 5 Compilers: gcc: 6.3.0 alt: 6 Client: Unknown python3.5 client inxi: 3.0.32
My problem :
flatpak run com.obsproject.Studio
(obs:3): dbind-WARNING **: 18:08:11.333: AT-SPI: Error retrieving accessibility bus address: {org.freedesktop.DBus.Error.ServiceUnknown: org.freedesktop.DBus.Error.ServiceUnknown}
Qt: Session management error: None of the authentication protocols specified are supported
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /app/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /app/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/locale/pt-BR.ini
Attempted path: /app/share/obs/obs-studio/locale/pt-BR.ini
info: Using preferred locale ‘pt-BR’
Attempted path: share/obs/obs-studio/themes/Dark.qss
Attempted path: /app/share/obs/obs-studio/themes/Dark.qss
info: CPU Name: AMD FX™-6300 Six-Core Processor
info: CPU Speed: 1400.000MHz
info: Physical Cores: 3, Logical Cores: 6
info: Physical Memory: 7887MB Total, 1867MB Free
info: Kernel Version: Linux 4.9.0-13-amd64
info: Distribution: “KDE Flatpak runtime” “5.14”
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.19.2
info: Portable mode: false
qt.svg: Cannot open file ‘/app/share/obs/obs-studio/themes/Dark/Close.svg’, because: No such file or directory
qt.svg: Cannot open file ‘/app/share/obs/obs-studio/themes/Dark/Popout.svg’, because: No such file or directory
Attempted path: share/obs/obs-studio/themes/Dark/no_sources.svg
Attempted path: /app/share/obs/obs-studio/themes/Dark/no_sources.svg
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_actionGridMode_triggered()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
info: OBS 25.0.8 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 44100
speakers: 2
info: Initializing OpenGL…
error: ARB_GLX_create_context not supported!
error: Failed to create context!
error: device_create (GL) failed
error: Failed to initialize video. Your GPU may not be supported, or your graphics drivers may need to be updated.
qt.glx: qglx_findConfig: Failed to finding matching FBConfig for QSurfaceFormat(version 2.0, options QFlagsQSurfaceFormat::FormatOption(), depthBufferSize -1, redBufferSize 1, greenBufferSize 1, blueBufferSize 1, alphaBufferSize -1, stencilBufferSize -1, samples -1, swapBehavior QSurfaceFormat::SingleBuffer, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::NoProfile)
No XVisualInfo for format QSurfaceFormat(version 2.0, options QFlagsQSurfaceFormat::FormatOption(), depthBufferSize -1, redBufferSize 1, greenBufferSize 1, blueBufferSize 1, alphaBufferSize -1, stencilBufferSize -1, samples -1, swapBehavior QSurfaceFormat::SingleBuffer, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::NoProfile)
Falling back to using screens root_visual.
info: Freeing OBS context data
info: == Profiler Results =============================
info: run_program_init: 5838,47 ms
info: ┣OBSApp::AppInit: 67,767 ms
info: ┃ ┗OBSApp::InitLocale: 4,899 ms
info: ┗OBSApp::OBSInit: 678,073 ms
info: ┣obs_startup: 2,129 ms
info: ┗OBSBasic::OBSInit: 10,926 ms
info: ┣OBSBasic::InitBasicConfig: 0,114 ms
info: ┣OBSBasic::ResetAudio: 0,145 ms
info: ┗OBSBasic::ResetVideo: 10,583 ms
info: obs_hotkey_thread(25 ms): min=0,117 ms, median=0,273 ms, max=6,624 ms, 99th percentile=0,722 ms, 100% below 25 ms
info: audio_thread(Audio): min=0,032 ms, median=0,048 ms, max=0,081 ms, 99th percentile=0,07 ms
info: =================================================
info: == Profiler Time Between Calls ==================
info: obs_hotkey_thread(25 ms): min=25,204 ms, median=25,383 ms, max=31,734 ms, 98,1651% within ±2% of 25 ms (0% lower, 1,83486% higher)
info: Number of memory leaks: 178
Tks for attention, good night folks
