Hello all,
I am running OBS Studio 30.1.0 On Fedora 38 with Chrome Version 122.0.6261.111 (Official Build) (64-bit). Youtube TV runs fine in chrome. But when I try to interact with Browser within OBS studio I get a video format not supported error.
Here is the OBS Log:
16:58:48.027: Using EGL/X11
16:58:48.027: CPU Name: Intel(R) Core™ i7-8650U CPU @ 1.90GHz
16:58:48.027: CPU Speed: 3898.432MHz
16:58:48.028: Physical Cores: 4, Logical Cores: 8
16:58:48.028: Physical Memory: 39987MB Total, 8469MB Free
16:58:48.028: Kernel Version: Linux 6.7.7-100.fc38.x86_64
16:58:48.028: Flatpak Branch: stable
16:58:48.028: Flatpak Arch: x86_64
16:58:48.028: Flatpak Runtime: runtime/org.kde.Platform/x86_64/6.6
16:58:48.028: App Extensions:
16:58:48.028: - com.obsproject.Studio.Locale
16:58:48.028: Runtime Extensions:
16:58:48.028: - org.freedesktop.Platform.GL.default
16:58:48.028: - org.freedesktop.Platform.VAAPI.Intel
16:58:48.028: - org.freedesktop.Platform.openh264
16:58:48.028: - org.kde.KStyle.Adwaita
16:58:48.028: - org.kde.PlatformTheme.QGnomePlatform
16:58:48.028: - org.kde.WaylandDecoration.QAdwaitaDecorations
16:58:48.028: - org.kde.Platform.Locale
16:58:48.028: Flatpak Framework Version: 1.15.4
16:58:48.028: Desktop Environment: GNOME (gnome)
16:58:48.028: Session Type: x11
16:58:48.028: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.14
16:58:48.030: Qt Version: 6.6.2 (runtime), 6.6.2 (compiled)
16:58:48.030: Portable mode: false
16:58:48.076: OBS 30.1.0 (linux)
16:58:48.076: ---------------------------------
16:58:48.076: audio settings reset:
16:58:48.076: samples per sec: 48000
16:58:48.076: speakers: 2
16:58:48.076: max buffering: 960 milliseconds
16:58:48.076: buffering type: dynamically increasing
16:58:48.080: ---------------------------------
16:58:48.080: Initializing OpenGL…
16:58:48.149: Loading up OpenGL on adapter Intel Mesa Intel(R) UHD Graphics 620 (KBL GT2)
16:58:48.149: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 24.0.3 (git-c4d371fa7e), shading language 4.60
16:58:48.190: ---------------------------------
16:58:48.190: video settings reset:
16:58:48.190: base resolution: 1280x720
16:58:48.190: output resolution: 1280x720
16:58:48.190: downscale filter: Bicubic
16:58:48.190: fps: 60/1
16:58:48.190: format: NV12
16:58:48.190: YUV mode: Rec. 709/Partial
16:58:48.191: NV12 texture support enabled
16:58:48.191: P010 texture support not available
16:58:48.199: Audio monitoring device:
16:58:48.199: name: Default
16:58:48.199: id: default
16:58:48.199: ---------------------------------
16:58:48.224: No AJA devices found, skipping loading AJA UI plugin
16:58:48.224: Failed to initialize module ‘aja-output-ui.so’
16:58:48.249: No AJA devices found, skipping loading AJA plugin
16:58:48.249: Failed to initialize module ‘aja.so’
16:58:48.259: Failed to load ‘en-US’ text for module: ‘decklink-captions.so’
16:58:48.272: Failed to load ‘en-US’ text for module: ‘decklink-output-ui.so’
16:58:48.283: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
16:58:48.283: Failed to initialize module ‘decklink.so’
16:58:48.615: [pipewire] Available captures:
16:58:48.615: [pipewire] - Desktop capture
16:58:48.615: [pipewire] - Window capture
16:58:48.654: v4l2loopback not installed, virtual camera disabled
16:58:48.671: [obs-browser]: Version 2.23.4
16:58:48.671: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2594+g17f8588+chromium-103.0.5060.134 (compiled)
16:58:48.690: VAAPI: API version 1.19
16:58:48.691: FFmpeg VAAPI H264 encoding supported
16:58:48.692: FFmpeg VAAPI AV1 encoding not supported
16:58:48.694: FFmpeg VAAPI HEVC encoding supported
16:58:48.836: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.4.2 | RPC Version: 1)
16:58:48.836: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.6.2 | Qt version (run-time): 6.6.2
16:58:48.836: [obs-websocket] [obs_module_load] Linked ASIO Version: 102900
16:58:48.844: [obs-websocket] [obs_module_load] Module loaded.
16:58:48.881: ---------------------------------
16:58:48.881: Loaded Modules:
16:58:48.881: text-freetype2.so
16:58:48.881: rtmp-services.so
16:58:48.881: obs-x264.so
16:58:48.881: obs-websocket.so
16:58:48.881: obs-webrtc.so
16:58:48.881: obs-vst.so
16:58:48.881: obs-transitions.so
16:58:48.881: obs-qsv11.so
16:58:48.881: obs-outputs.so
16:58:48.881: obs-libfdk.so
16:58:48.881: obs-filters.so
16:58:48.881: obs-ffmpeg.so
16:58:48.881: obs-browser.so
16:58:48.881: linux-v4l2.so
16:58:48.881: linux-pulseaudio.so
16:58:48.881: linux-pipewire.so
16:58:48.881: linux-jack.so
16:58:48.881: linux-capture.so
16:58:48.881: image-source.so
16:58:48.881: frontend-tools.so
16:58:48.881: decklink-output-ui.so
16:58:48.881: decklink-captions.so
16:58:48.881: ==== Startup complete ===============================================
16:58:48.930: All scene data cleared
16:58:48.930: ------------------------------------------------
16:58:48.935: pulse-input: Server name: ‘PulseAudio (on PipeWire 1.0.3) 15.0.0’
16:58:48.936: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
16:58:48.936: pulse-input: Started recording from ‘alsa_output.pci-0000_00_1f.3.analog-stereo.monitor’ (default)
16:58:48.936: [Loaded global audio device]: ‘Desktop Audio’
16:58:48.937: pulse-input: Server name: ‘PulseAudio (on PipeWire 1.0.3) 15.0.0’
16:58:48.937: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
16:58:48.937: pulse-input: Started recording from ‘alsa_input.pci-0000_00_1f.3.analog-stereo’ (default)
16:58:48.937: [Loaded global audio device]: ‘Mic/Aux’
16:58:48.942: Switched to scene ‘Scene’
16:58:48.942: ------------------------------------------------
16:58:48.942: Loaded scenes:
16:58:48.942: - scene ‘Scene’:
16:58:48.942: - source: ‘Browser’ (browser_source)
16:58:49.741: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Desktop Audio)
16:58:49.741:
16:58:49.783: adding 21 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
16:58:49.783:
16:58:51.865: [obs-browser: ‘Browser’] Error: [Report Only] This document requires ‘TrustedHTML’ assignment. (:1)
