OpenSSL issue in com.makemkv.MakeMKV
There appears to be an issue in the flatpak version of MakeMKV which is causing the application to fail to read and copy disk information. There is a thread on the MakeMKV linux forum that captures this based on the “Internal error: openssl test 0050 failed” error that the application generates on open (a Google search will find it, as I assume external links are not permitted).
The current theory is that the version of openssl in the flatpak may be involved.
This is just a heads up that this particular App flatpak is broken at the moment.
-pm
See Internal error: openssl test 0050 failed · Issue #63 · flathub/com.makemkv.MakeMKV · GitHub
Thank you… that is very helpful. I will be sure to monitor the issue.
pm
