It seems packages org.freedesktop.Platform.VAAPI.Intel
and org.freedesktop.Platform.html5-codecs
are trying to be updated always.
In the Op
column it goes from i
to r
and then back to i
, and they always update.
❯ flatpak update
Looking for updates…
Info: org.gnome.Platform//3.36 is end-of-life, with reason:
The GNOME 3.36 runtime is no longer supported as of February 13, 2021. Please ask your application developer to migrate to a supported platform.
Applications using this runtime:
com.github.calo001.fondo, org.gnome.OCRFeeder
Info: org.freedesktop.Platform.html5-codecs//18.08 is end-of-life, with reason:
The Freedesktop SDK 18.08 runtime is no longer supported as of 31th August 2020. Please ask your application developer to migrate to a supported platform.
Info: org.freedesktop.Platform.VAAPI.Intel//18.08 is end-of-life, with reason:
ID Rama Op
1. [-] org.freedesktop.Platform.VAAPI.Intel 18.08 r
2. [-] org.freedesktop.Platform.html5-codecs 18.08 r
Uninstall complete.
❯ flatpak update
ID Rama Op Remoto Descarga
1. [✓] org.freedesktop.Platform.VAAPI.Intel 18.08 i flathub 1,8 MB / 1,8 MB
2. [✓] org.freedesktop.Platform.html5-codecs 18.08 i flathub 3,0 MB / 3,3 MB
Installation complete.
❯ flatpak update
ID Rama Op
Uninstall complete.
❯ flatpak update
Weird. What’s happening?
