Passing cmake options setting via yaml/json flatpak config?
My project’s CMakeLists.txt has some custom options which I set to help configure the build.
How should one pass such settings via Flatpak yaml/json file ?
Cheers
You can use
config-opts:
      - -Option=Value
A example Manifest which uses this can be found here.
