I have installed Flatpak on Debian 11 but it can find or search for any known items like VLC. I get the following. I am using version Flatpak 1.10.7. What could be wrong
flathub doesn’t support any 32 bit architectures. So that’s expected.
C
compis
#5
What is the reason. Flatpak installs on a 32 bit machine with no Error message and its just a repository so if an app like VLC exists for the 32 bit platform why not flatpak?
And I said in the other thread, 32-bits runtime are no longer supported. That doesn’t prevent flatpak from working, just that there is no software packages for it anymore.
I understand. If flatpak does not provide any 32 bit software packages it should warn users that no packages are supported since it would be useless for 32 bit systems.
