aude
September 14, 2021, 11:01am
#1
I’ve installed linux and jamovi on my chromebook as explained in jamovi tutos.
But when I open Jamovi appli, it closes one second after with the message :
“Engine process terminated Exit code: -6”
What does it mean? How to fix it?
Thanks!
hub
September 14, 2021, 5:16pm
#2
It think the problem been reported there:
opened 02:11PM - 14 Sep 21 UTC
Hello,
when I try to start jamovi (jamovi org.jamovi.jamovi 2.0.2 stable system… )
it crashes:
enrico@enrico-cubi:~$ flatpak run org.jamovi.jamovi
[5 zypak-helper] Portal v4 is not available
Gtk-Message: 16:08:55.652: Failed to load module "xapp-gtk3-module"
jamovi
version: 0.0.0
cli: 0.0.0
ports: 38767, 33221, 46667
jamovi.server.session - creating instance: cfc33bf2-70ab-4492-b14a-c5a74f4466bc
instance_started cfc33bf2-70ab-4492-b14a-c5a74f4466bc
terminate called without an active exception
jamovi.server.engine - Engine crash (spontaneous) with exit code -6
[13 zypak-sandbox] Dropping 0x1d85240 (3) because of connection closed
[13 zypak-sandbox] Host is gone, preparing to exit...
[13 zypak-sandbox] Quitting Zygote...
