Hi, I have this problem: when I launch SpeechNote I get these errors:
ERROR: ld.so: object ‘/usr/lib/libgtk3-nocsd.so.0’ from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
ALSA lib …/…/oss/pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib …/…/…/src/pcm/pcm_direct.c:2045:(snd1_pcm_direct_parse_open_conf) The field ipc_gid must be a valid group (create group audio)
What can I do? Thank you.
