I’ve had the last 2 main branch builds of totem fail to be published for a reason I don’t understand.
In the “publishing builds” phase, it says:
Publishing build https://hub.flathub.org/api/v1/build/73749
Api call to https://hub.flathub.org/api/v1/build/73749/publish failed with status 400, details: {'status': 400, 'error-type': 'no-error', 'message': 'No json error details from server'}
It worked the 3rd time, after a day. The worse part of it is that the build appears as successful in the builds overview. Is flathub/flathub the place to report those, or is there a specific repo for build system problems?
