So, I’m attempting to make a Flatpak of the Amulet Minecraft Map Editor. I feed my requirements.txt to flatpak-pip-generator, save the output (in YAML) to amulet.yml , and run this:
flatpak-builder --sandbox --user --install-deps-from=flathub --mirror-screenshots-url=https://dl.flathub.org/media/ --add-tag=0.10.35 --bundle-sources --repo=amulet_flatpak_repo amulet_build_dir amulet.yml --force-clean
And it after a while, it fails on pyyaml:
Building module python3-pre-commit in /home/evilsupahfly/Downloads/Amulet/.flatpak-builder/build/python3-pre-commit-1
Running: pip3 install --verbose --exists-action=i --no-index --find-links="file://${PWD}" --prefix=${FLATPAK_DEST} "pre-commit>=1.11.1" --report=pip_report.json --no-build-isolation
Using pip 24.1.2 from /usr/lib/python3.11/site-packages/pip (python 3.11)
Looking in links: file:///run/build/python3-pre-commit
Processing ./pre_commit-3.8.0-py2.py3-none-any.whl
Processing ./cfgv-3.4.0-py2.py3-none-any.whl (from pre-commit>=1.11.1)
Processing ./identify-2.6.0-py2.py3-none-any.whl (from pre-commit>=1.11.1)
Processing ./nodeenv-1.9.1-py2.py3-none-any.whl (from pre-commit>=1.11.1)
INFO: pip is looking at multiple versions of pre-commit to determine which version is compatible with other requirements. This could take a while.
ERROR: Could not find a version that satisfies the requirement pyyaml>=5.1 (from pre-commit) (from versions: none)
ERROR: No matching distribution found for pyyaml>=5.1
Error: module python3-pre-commit: Child process exited with code 1
Can anybody tell me why PyYAML hates me?
Edit: I wasn’t spamming. I was asking for help.
bbhtt
August 13, 2024, 1:58am
2
Seems like an issue with the order. It’s probably trying to install pre-commit before installing pyyaml, but the former depends on the latter.
I’ll switch up the order then and see what happens.
Using my new requirements.txt , I have a new amulet.yml . and I’m still up against the wall:
Building module python3-pyyaml in /home/evilsupahfly/Downloads/Amulet/.flatpak-builder/build/python3-pyyaml-6
Running: pip3 install --verbose --no-index --find-links="file://${PWD}" --prefix=${FLATPAK_DEST} "pyyaml==6.0.2" --report=pip_report.json --no-build-isolation
FB: Running: flatpak build --die-with-parent --env=FLATPAK_BUILDER_BUILDDIR=/run/build/python3-pyyaml --nofilesystem=host:reset --filesystem=/home/evilsupahfly/Downloads/Amulet/.flatpak-builder/build/python3-pyyaml-6 --bind-mount=/run/build/python3-pyyaml=/home/evilsupahfly/Downloads/Amulet/.flatpak-builder/build/python3-pyyaml-6 --build-dir=/run/build/python3-pyyaml --bind-mount=/run/ccache=/home/evilsupahfly/Downloads/Amulet/.flatpak-builder/ccache --env=SOURCE_DATE_EPOCH=1723521830 '--env=CFLAGS=-O2 -pipe -g -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions -fstack-protector-strong -grecord-gcc-switches -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer ' '--env=CXXFLAGS=-O2 -pipe -g -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions -fstack-protector-strong -grecord-gcc-switches -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer ' '--env=LDFLAGS=-L/app/lib -Wl,-z,relro,-z,now -Wl,--as-needed ' --env=CCACHE_DIR=/run/ccache/disabled --env=PATH=/app/bin:/usr/bin --env=LD_LIBRARY_PATH=/app/lib --env=PKG_CONFIG_PATH=/app/lib/pkgconfig:/app/share/pkgconfig:/usr/lib/pkgconfig:/usr/share/pkgconfig --env=FLATPAK_BUILDER_N_JOBS=8 /home/evilsupahfly/Downloads/Amulet/.flatpak-builder/rofiles/rofiles-CdIlSx /bin/sh -c 'pip3 install --verbose --no-index --find-links="file://${PWD}" --prefix=${FLATPAK_DEST} "pyyaml==6.0.2" --report=pip_report.json --no-build-isolation'
Looking in links: file:///run/build/python3-pyyaml
ERROR: Could not find a version that satisfies the requirement pyyaml==6.0.2 (from versions: none)
ERROR: No matching distribution found for pyyaml==6.0.2
Error: module python3-pyyaml: Child process exited with code 1
FB: Unmounting read-only fs: fusermount -uz /home/evilsupahfly/Downloads/Amulet/.flatpak-builder/rofiles/rofiles-CdIlSx
This time I manually edited amulet.yml to fill out the pyyaml section and ran with the --verbose flag to see if I could get anything more useful.
Before:
- name: python3-pyyaml
- pip3 install --verbose --exists-action=i --no-index --find-links="file://${PWD}"
--prefix=${FLATPAK_DEST} "pyyaml~=6.0" --report=pip_report.json --no-build-isolation
sources: []
After:
- type: file
url: https://files.pythonhosted.org/packages/6b/4e/1523cb902fd98355e2e9ea5e5eb237cbc5f3ad5f3075fa65087aa0ecb669/PyYAML-6.0.2-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl
sha256: ec031d5d2feb36d1d1a24380e4db6d43695f3748343d99434e6f5f9156aaa2ed
Edit: There’s a ton of info on pypi.org and I don’t know if it’s being somehow missed or just ignored but even my manual override failed.
Edit 2: I don’t know why this was flagged as spam. I didn’t do anything spammy.
bbhtt
August 13, 2024, 4:50am
5
Freedesktop SDK has python 3.11, you are using a wheel for python 3.10
If you want to use wheels choose the correct one https://files.pythonhosted.org/packages/67/a4/1f5fbd3f58d4069000522196b0b776a014f3feec1796da03e495cf23532d/lxml-5.3.0-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl
Or use the sdist https://files.pythonhosted.org/packages/e7/6b/20c3a4b24751377aaa6307eb230b66701024012c29dd374999cc92983269/lxml-5.3.0.tar.gz
lxml isn’t pyyaml but I see from your example how they’ve included the Python version as part of the filename, which I didn’t realize. Or just didn’t see.
We’ll try again with
- pip3 install --verbose --no-index --find-links="file://${PWD}" --prefix=${FLATPAK_DEST}
- type: file
url: https://files.pythonhosted.org/packages/75/e4/2c27590dfc9992f73aabbeb9241ae20220bd9452df27483b6e56d3975cc5/PyYAML-6.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl
sha256: 3ad2a3decf9aaba3d29c8f537ac4b243e36bef957511b4766cb0057d32b0be85
bbhtt
August 13, 2024, 5:10am
7
Ah yea I was thinking about something else and misread it for pyyaml.
Thanks to you pointing out the fact that I was calling version, after correcting it, we’re back in business and no more crashing!
I still don’t know why it wasn’t able to do it itself, but that’s something I can look at later, now that it’s working.
Why was this thread flagged as spam?!
I would think pastebin would be exempt from that rule, given how instrumental it is in keeping posts looking clean and tidy, but I’ll be mindful of this going forward.
