Q: Push to github/flathub without build?
Hi out there!
Is there a way to push commits to github/flathub projects without causing a build? I envision some kind of magic stuff in the commit message which disables the build bot, similar to [noci] commonly used to disable ci builds
Bump, I would like to move screenshots to the flathub repo, add a readme, update the metadata for the next release, but don’t need a test build each time and feel bad eating CPU time!
There is no such thing, screenshot changes and metadata changes are expected to be in sync with what is in the remote. Unless you’re on a branch/beta branch.
This topic was automatically closed after 2 days. New replies are no longer allowed.
