Project information: ShadowPC Client
Homepage: https://shadow.tech
I try to make a ShadowPC client Flatpack.
So long i am:
manifest:
app-id: stream.ShadowTech.ShadowLancher
runtime-version: '22.08'
command: /app/start.sh
base-extensions:
- org.freedesktop.Platform.GL.default
- org.freedesktop.Platform.ffmpeg-full
- org.freedesktop.Platform.openh264
- name: StartScript
- install -D start.sh /app/start.sh
- type: file
path: ./start.sh
- name: Shadow-Lancher
- ./Shadow.AppImage --appimage-extract
- cp -r squashfs-root/* /app/
- type: file
path: ./Shadow.AppImage
cleanup:
- './Shadow.AppImage'
- name: syslib
- cp -v *.so.* /app/lib/
- type: archive
path: ./syslib.zip
sha256: 55f4b76cb67f2ac352afbf4f6444c50f9e89a39f598cd19112339b0336cfd0cc
- name: shadowaddlib
- type: archive
path: ./shadow.asarLibs.zip
sha256: 5dea80353a70b7eed8a24375460562900b7598207354b261628a6c17a56a63a3
- --share=ipc
- --socket=x11
- --socket=wayland
- --share=network
- --device=dri
- --socket=pulseaudio
- --system-talk-name=org.freedesktop.login1
- --persist=.cache
the asart Lib can be get here:
https://gitlab.com/uploads/-/system/personal_snippet/2189195/c0b55d86a01266c2dfe49b7b325fabe5/shadow.asarLibs.zip
In the syslib is:
- libevdev.so.2
- libinput.so.10
- libmtdev.so.1
- libva-glx.so.2
- libwacom.so.2
copy from system.
in start.sh is:
#!/usr/bin/env bash
cd /app
./shadow-launcher --no-sandbox
And the AppImage can get from the Shadow Tech Side.
Primary:
I get a Error R-0x7F if i start the stream. The support say that is a connect error.
What can i try now?
Secondary:
How do i find lib tarball to install the system libs directly?
Is the extensions correct?
Need i the extensions?
(If i need the shadow.asarLibs i must try self. I have hope that the libs fix the error.)
