Besides not being updated in more than 17 months, there already is another package for Teams that is actively maintained (https://flathub.org/apps/details/com.microsoft.Teams).
For the sake of cleanliness, should this package be retired?
https://flathub.org/apps/details/com.github.IsmaelMartinez.teams_for_linux
Itâs up to the application maintainer to EOL their app if they donât want to maintain it anymore.
Iâm wondering the the flathub maintainers should retire any application as soon as they become maintained by their developers and that doesnât have any other distinguishable features (something like VSCode-OSS is to VSCode).
I find it confusing that a user can find both Teams applications without any clear indications that only one is actually up-to-date and supported by the developers. Itâs just a bad user experience (as it can be seen from the screen above).
by their developers
Itâs a completely different client(electron wrapper thatâs) not just a re-packaged version of the same âMicrosoft teamsâ client, it clearly mentions that on itâs summary.
Thereâs nothing actionable here unless the application maintainer wants to End-Of-Life their application.
Fair enough. I was under the impression that the official supported application was also an electron wrapper thatâs why I believed that itâs duplicated. If they are indeed different, you are right.
They are probably both electron wrappers yes, but thatâs not up to me to decide whether they are exactly the same or not or whether one is okay to be removed or not. If you think the unofficial client is problematic, you should probably open an issue and discuss that with the upstream developer of the said application
Still a normal user cannot infer anything meaningful from the summary. (If the difference is not even clear to technically savvy people.) The only info a normal user can process are:
- one is official Microsoft app, but âPreviewâ
- other is not official, but it is not a âPreviewâ and comes before the official one in the list.
Conclusion: the unofficial one is more mature, more reliable.
I would suggest to put the âLast updateâ or update frequency in the summary. As it stands it is misleading
