Speech Note dont start on Linux Mint 20.3
I installed speechnote on linux with the following command “flatpak install flathub net.mkiol.SpeechNote” and it worked correctly.
then when I run with “flatpak install flathub net.mkiol.SpeechNote”
It doesn’t run and gives me this message:
franklin@HP-Microtower:~$ flatpak run net.mkiol.SpeechNote
Gtk-Message: 09:54:39.968: Failed to load module “xapp-gtk3-module”
Qt: Session management error: Could not open network socket
ALSA lib …/…/oss/pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib …/…/…/src/pcm/pcm_direct.c:2045:(snd1_pcm_direct_parse_open_conf) The field ipc_gid must be a valid group (create group audio)
Can someone tell me what I can do to solve it?
Thank
I’ve got same error
trying to install xapp failed libxapp1 (= 2.2.8-1) but 2.6.1+victoria in required
Looks like you’re using a deb package and not a Flatpak
I got a similar issue and fixed it after many tries with Claude! I installed SpeechNote on an old HP laptop with Intel GPU and 16Gb of RAM. At launch, it was loading constantly with a black screen without any hint. I fixed it by installing the NVidia addon with flatpak install flathub net.mkiol.SpeechNote.Addon.nvidia (it failed to install the AMD one, due to a lack of RAM). I hope this helps someone later on…
