hello guys need to file an error and hope it gets solved.
fedora KDE latest the spotify app is crashing all the time cant use it. wanted to file the error so it gets solved quick
Hi, welcome to the Flathub Discourse!
First of all, this forum is more about general discussion about Flathub and Flatpak. If you need support with an specific app, its recommended to use the applications help resources. If you look the app up on Flathub.org, you can find a “Report an issue” link for the app.
Secondly, just “app crashes all the time” is unfortunately not enough information.
You should provide information about the system (Flatpak version, is app up-to-date), your steps which causes the crash (is this after an specific action?) and, ideally, in the case of a crash a back trace (see the Flatpak section especially.
hello thanks for reply. i use latest flatpak in fedora, installed latest stable spotify app. when i click on the icon to start the app it crashes instantly without an error, sometimes the error reporter of fedora pops up but the error reporting tool cant find enough information to file an error to the developersidk whats a back trace
try running it from the commandline/terminal
flatpak run com.spotify.Client
this does not help it shows the spotify window but crashes instant
What does it print in your commandline?
the problem is this a proprietary and only Spotify can fix it. And they don’t support flatpak because why would they.
There’s a thread describing similar issues, including some possible workarounds, on the manifest repo for Spotify: Doesn't launch · Issue #277 · flathub/com.spotify.Client · GitHub
