Ubuntu 18.04 LTR
GIMP 2.10, installed w/flatpak on both local and remote
local% flatpak run org.gimp.GIMP // works
local% ssh -X remote
remote% flatpak run org.gimp.GIMP // console shows running but no display
Are flatpak apps compatible with this approach (running them over the network with X-forwarding)?
If so, is there something I as a user need to configure?
If not, is it something the packager needs to do at packaging time?
I was disappointed to find out that Ubuntu offers only GIMP 2.8 from its apt store, then excited to learn 2.10 could be had from flatpak, then disappointed again to find it can’t be run in my accustomed way. (The more powerful server does not have a “seat” in front of it.)
Flatpak is designed to run inside a desktop session and relies on
certain session services, such as a D-Bus session bus and, optionally, a
systemd --user instance. **This makes Flatpak not a good match for a ** server.
However, the build features of Flatpak run fine outside a session, so
you can build things on a server.[/quote]
Well. That’s clear enough.[1] Love the idea. Need the server. Checking back later.
Looking forward to it.
Thank you.
[1] Clearer than figuring out how to format it in the post…
