mirekua
February 16, 2023, 6:52pm
#1
I use CentOS 9 + flatpak. Every time after updates the fonts in flatpak apps switch to squares. Multiple cyrillic languages installed on the system.
Usually I use command flatpak run --command=fc-cache App -f -v
But it’s terrible In fact it’s will enough if flatpak Apps show me english instead of this terrible attempts to show me texts in native languages
But i do not know how to switch flatpak only to 1 language How i can do it ?
cxrvh
February 19, 2023, 5:46pm
#2
I think you set the language with with flatpak config :
flatpak config --user --set languages "en;"
You probably have to download the Locales manually for each app & runtime (see Using different language for application is magic · Issue #1504 · flatpak/flatpak · GitHub ). But I’m not sure if this is the case, maybe a simple flatpak update
is enough.
But it’s possible that this is a GNOME runtime bug (Gnome Platform 43 fc-cache failed ). Then you could see the same issue with any other language, too.
