Project information: A Linux compatible UI for the Elgato Stream Deck.
Homepage: streamdeck-ui
License: MIT
Upstream has been contacted: no, but he’s aware on the former attempts
This pre cooked installation script might help alot on the flatpak creation: https://github.com/timothycrosley/streamdeck-ui/blob/master/scripts/ubuntu_install.sh
Stream Deck UI is a very handy and helpful software for streamers:
Usage of all Stream Deck devices on Linux without needing to code. Multi-device: Enables connecting and configuring multiple Stream Deck devices on one computer.
Brightness Control: Supports controlling the brightness from both the configuration UI and buttons on the device itself.
Configurable Button Display: Icons + Text, Icon Only, and Text Only configurable per button on the Stream Deck.
Multi-Action Support: Run commands, write text and press hotkey combinations at the press of a single button on your Stream Deck.
Button Pages: streamdeck_ui supports multiple pages of buttons and dynamically setting up buttons to switch between those pages.
Auto Reconnect: Automatically and gracefully reconnects, in the case the device is unplugged and replugged in.
Import/Export: Supports saving and restoring Stream Deck configuration
