System-wide DRI_PRIME environment variable for all Flatpaks - is there a solution?
Hello everyone,
I’m running Arch Linux with GNOME on a laptop with hybrid graphics:
  • Device 0: AMD Radeon 890M (integrated GPU)
  • Device 1: AMD Radeon RX 7700S (discrete GPU via PCIe Gen 4)
The Problem:
Many of my Flatpak applications (Bitwarden, etc.) are being assigned to the discrete GPU (Device 1) by GNOME/Mutter, even though they don’t use any GPU acceleration and just waste resources. This seems to happen automatically, and I haven’t found a clear pattern for why certain apps get assigned to which GPU.
I want to force all Flatpak applications to use the integrated GPU (DRI_PRIME=0) by default to save power and system resources.
What I’ve tried:
  1. Using Flatseal to set DRI_PRIME=0 per application — this works but requires manual configuration for every single app
My Questions:
  1. Is there a way to set environment variables system-wide for all Flatpaks without configuring each app individually?
  2. Are there other approaches to control GPU assignment for Flatpak applications?
Additional context:
  • Flatpak version: 1.16.3
Any insights or workarounds would be greatly appreciated!
Thanks in advance!
You may set flatpak override --user --env=DRI_PRIME=0 and it will work for all apps.
This topic was automatically closed after 4 days. New replies are no longer allowed.
