I have just installed TeXlive 2023 and TeXworks 0.6.8.
I can compile my TEX file from the terminal via pdflatex …, but not within TeXworks which says :
pdfLaTeX is not configured correctly
Is there a fix somewhere?
How did you install TeXLive? Did you install org.freedesktop.Sdk.Extension.texlive//22.08 or texlive from TeX Live - TeX Users Group (tug.org)?
The first one should work out of the box, the second needs manual pointing to your pdflatex binary.
I have installed the TeXlive from TeX Live - TeX Users Group.
So I need to give the full path to pdflatex? Am I right?
Yes, in your case you have to give the absolute path to pdflatex.
Or you just install the texlive extension
