Thunderbird data
I’m posting on here because there is no response on the Thunderbird forum, however the fact that Thunderbird is now a Flatpak is relevant.
I’ve just installed Fedora-36 on a clean disk and copied the data from my old disk. When I have done this in the past Thunderbird used to find my profile and therefore the emails. Now it doesn’t, and copying the .thunderbird directory or the .default profile to /home/chris/.thunderbird doesn’t work either.
I tried Copying the .thunderbird directory from old computer onto new computer no longer works. | Thunderbird Support Forum | Mozilla Support, but “On your destination computer Locate the “Profile Folder” entry, then click Open Directory.” doesn’t do anything.
Now Thunderbird won’t even start, I just get “Your Thunderbird profile cannot be loaded. It may be missing or inaccessible.”
I suspect that the last time I did this successfully Thunderbird was an RPM package and it has since changed to a Flatpak, which probably means that data files are located somewhere different. I need to delete the lot, install Thunderbird again, then copy the data files to the Flatpak location. With a deb package you can use “purge”, is there a Flatpak equivalent? If not which directories should I delete and where should I copy the profile file afterwards?
Instructions about migrating TB data from non-flatpak to flatpak are provided here. Note this is related to Flathub version of Thunderbird while Fedora provides separate Thunderbird flatpak for which those may not apply.
It enabled me to start Thunderbird and create a new profile, surprisingly that was in ~ not the Flatpak directory. It still wasn’t possible to switch to my profile using Thunderbird. I deleted the new profile and changed the name of my profile to that. It fooled Thunderbird, so I now have my emails back. Thanks!
