I’m trying to build Flatpak on Debian/bookworm using Meson based on the sources in the GitHub repo and the instructions in:
flatpak/CONTRIBUTING
When I cd into the repo and run:
sudo apt build-dep flatpak
I get:
Reading package lists… Done E: You must put some ‘deb-src’ URIs in your sources.list
What am I missing?
You need to enable the source repositories on Debian. If you have the “Software and Updates” app it should have a checkbox to do that, otherwise edit /etc/apt/sources.list, copy each line and add deb-src in front of it.
deb-src
Then run # apt update
# apt update
See SourcesList - Debian Wiki for examples.
