I am a newcomer using flatpak (I had some experience in the past). I created an extension org.freedesktop.Sdk.Extension.nim
branch: '23.08'
runtime: org.freedesktop.Sdk
build-extension: true
runtime-version: '23.08'
build-options:
prefix: /usr/lib/sdk/nim
- --share=network # We need this to install libraries with `nimble`
- name: nim
- type: file #archive
only-arches:
- x86_64
dest: download
url: https://nim-lang.org/download/nim-2.2.0-linux_x64.tar.xz
sha256: 942e047879fd81193b2ff3c105436a0c5016800c4e97864f90039ae204f89ded
build-options:
prefix: /app/extensimcon_directory/nim
prepend-path: /app/extension_directory/nim/bin
- tar -xf download/nim-2.2.0-linux_x64.tar.xz
- install -v -Dm755 nim-2.2.0/bin/* -t ${FLATPAK_DEST}/bin/
I built it like:
flatpak-builder --force-clean --user --install ./tmpdir org.freedesktop.Sdk.Extension.nim.yml
At this point, if I debug the extension:
$ flatpak-builder --run ./tmpdir org.freedesktop.Sdk.Extension.nim.yml sh
sh-5.2$ /usr/lib/sdk/nim/bin/nim --version
Nim Compiler Version 2.2.0 [Linux: amd64]
Compiled at 2024-10-02
Copyright (c) 2006-2024 by Andreas Rumpf
git hash: 78983f1876726a49c69d65629ab433ea1310ece1
active boot switches: -d:release
Then, I would to use it in an app org.gnome.myapp.yml
runtime: org.gnome.Platform
runtime-version: '47'
sdk: org.gnome.Sdk
command: myapp
sdk-extensions:
- org.freedesktop.Sdk.Extension.nim:
version: '23.08'
append-path: /usr/lib/sdk/nim/bin
- name: myapp
- nimble install owlkettle
- nimble build
- install -Dm755 myapp /app/bin/myapp
I build it and it fails in one of the steps (it doesn’t find nimble
$ flatpak-builder --user --force-clean --install ./tmpdir org.gnome.myapp.yml
If I debug it, /usr/lib/sdk
appears empty. I would expect that to contain nim
folder.
$ flatpak-builder --run ./tmpdir org.gnome.myapp.yml sh
sh-5.2$ ls /usr/lib/sdk
sh-5.2$
What am I doing wrong?
