Hey guys
Tutanota quitting unexpectedly on Fedora 39 constantly
This error has been occurring for more than two months.
Can anyone check what is happening?
The application opens, takes more than 5 minutes for the emails to appear and then everything freezes and exits unexpectedly as shown in the image below:
The connection is fine here and the error occurs with or without VPN as well.
Log below:
2024-02-13T23:15:48.869Z I "the monkey has been patched pid:",2
2024-02-13T23:15:52.604Z I "version: ","3.122.5"
2024-02-13T23:15:52.738Z I "resolving key...","tutanota-vault"
2024-02-13T23:15:52.845Z I "config up to date"
2024-02-13T23:15:53.565Z I "[2024-02-13T23:15:53.565Z]","using safeStorage with backend","gnome_libsecret"
2024-02-13T23:15:53.573Z I "[2024-02-13T23:15:53.573Z]","Create tray:true"
2024-02-13T23:15:53.577Z I "[ApplicationWindow]","webAssetsPath: ","/app/lib/tutanota/resources/app.asar"
2024-02-13T23:15:53.684Z I "[ApplicationWindow]","getting dictionaries from:","https://app.tuta.com/desktop//dictionaries/"
2024-02-13T23:15:53.705Z I "default mailto handler:",false
2024-02-13T23:15:53.706Z I "Webapp ready"
2024-02-13T23:15:53.707Z I "[2024-02-13T23:15:53.707Z]","[ElectronUpdater]","DEBUG:","no update info on disk, disabling updater."
2024-02-13T23:15:53.727Z I "[DesktopSseClient]","scheduling to check sse in",1,"seconds"
2024-02-13T23:15:53.743Z I "/home/edson/.var/app/com.tutanota.Tutanota/data/applications/tutanota-desktop.desktop does not exist, checking for permission to ask for permission..."
2024-02-13T23:15:54.733Z I "[DesktopSseClient]","last missed notification check:",{"lastMissedNotificationCheckTime":1707617675103}
2024-02-13T23:15:54.733Z I "[DesktopSseClient]","scheduling to check sse in",100,"seconds"
2024-02-13T23:15:54.735Z I "[DesktopSseClient]","starting sse connection"
2024-02-13T23:15:54.845Z I "lookup sse request"
2024-02-13T23:15:55.972Z I "[ApplicationWindow]","spellcheck-dictionary-initialized","pt-BR"
2024-02-13T23:15:55.994Z I "established SSE connection with code",200
2024-02-13T23:15:55.996Z I "[DesktopSseClient]","received new timeout:","heartbeatTimeout:240"
2024-02-13T23:15:55.996Z I "[DesktopSseClient]","scheduling to check sse in",288,"seconds"
2024-02-13T23:15:55.996Z I "[DesktopSseClient]","sse heartbeat",240
2024-02-13T23:15:55.997Z I "[DesktopSseClient]","scheduling to check sse in",288,"seconds"
2024-02-13T23:15:56.051Z I "[DesktopSseClient]","sse heartbeat",240
2024-02-13T23:15:56.051Z I "[DesktopSseClient]","scheduling to check sse in",288,"seconds"
2024-02-13T23:15:56.053Z I "[DesktopSseClient]","downloading missed notification"
2024-02-13T23:15:56.057Z I "[DesktopSseClient]","lookup"
2024-02-13T23:15:57.176Z I "[DesktopSseClient]","missed notification response",200
2024-02-13T23:15:57.180Z I "[DesktopSseClient]","dl missed notification response closed"
2024-02-13T23:15:57.180Z I "[DesktopSseClient]","MissedNotification is empty"
2024-02-13T23:15:57.180Z I "[DesktopSseClient]","scheduling to check sse in",288,"seconds"
2024-02-13T23:16:00.289Z I "resolving key...","tutanota-credentials"
2024-02-13T23:16:00.348Z I "[PerWindowSqlCipherFacade]","open db for","NTEdjwi--J-9"
2024-02-13T23:16:00.355Z I "[2024-02-13T23:16:00.355Z]","[WorkerSqlCipher]","started sqlcipher-worker-1"
2024-02-13T23:16:00.449Z I "[2024-02-13T23:16:00.449Z]","[sqlcipher-worker-1]","set up sql cipher done"
2024-02-13T23:18:16.307Z I "[DesktopSseClient]","storing push identifier"
2024-02-13T23:19:55.991Z I "[DesktopSseClient]","sse heartbeat",240
2024-02-13T23:19:55.991Z I "[DesktopSseClient]","scheduling to check sse in",288,"seconds"
2024-02-13T23:22:16.305Z I "[PerWindowSqlCipherFacade]","close db for","NTEdjwi--J-9"
2024-02-13T23:22:16.307Z I "[ApplicationWindow]","closing offline db for userId NTEdjwi--J-9"
2024-02-13T23:22:16.307Z I "[PerWindowSqlCipherFacade]","close db for",
2024-02-13T23:22:16.589Z I "[2024-02-13T23:22:16.589Z]","[OfflineDbRefCounter]","closed db for","NTEdjwi--J-9"
2024-02-13T23:22:20.748Z I "resolving key...","tutanota-credentials"
2024-02-13T23:22:21.918Z I "[OfflineDbRefCounter]","Deleting db for user NTEdjwi--J-9"
2024-02-13T23:22:21.918Z I "deleting db for","NTEdjwi--J-9"
2024-02-13T23:22:21.920Z I "[OfflineDbRefCounter]","Deleted db for user NTEdjwi--J-9"
2024-02-13T23:22:22.511Z I "[DesktopSseClient]","Removing user","NTEdjwi--J-9"
2024-02-13T23:22:22.543Z I "[DesktopWindowManager]","invalidating alarms for window",1
