Ultimaker cura - problem import STL
Hi, my name “Luigi”, from italy. My english elemetary.
My problem Ultimaker Cura 5.7.2 no import STL?
How to fixed problem from flatseal permession ?
Thanks.
ok, fix solved problem import slow STL.
Open cura
Disable plugin USB priting.
Restart cura
Fixed problem.
Thanks ,
My search google fix problem
Weird, pretty sure I can just load them via drag and drop on my end.
