I installed OBS on my Chromebook, but when I tried to run it, it gives me this:
bwrap: Can’t mount proc on /newroot/proc: Operation not permitted
error: ldconfig failed, exit status 256
Is there any way to fix this?
Hmmm, chromebook. Could you have an ARM processor?
OBS on flathub does not have ARM support yet.
It wouldn’t even install.
1- Press Ctrl+Alt+T
2- A terminal window will open, this is different than crostini terminal, and called crosh. Now type “vsh termina” on it and press enter
3- Now type “lxc config set penguin security.nesting true” then press enter.,
4- Restart your computer, it should work now.
