Hi, I am working on a project that uses python3. How can you use updated pip and other newer packages? My runtime version is 21.08, as is my base version. I would like to keep those the same. All attempts to update packages like cython are stopped with errors that the file system is read only. Here is some output from a section of my yaml manifest file.
- cython --version ## I would like 0.29.32
- python3 --version
- which python3
- python3 -m pip install --upgrade pip ## I'd like to use latest
This is the output.
Running: cython --version
Cython version 0.29.28
Running: python3 --version
Python 3.9.9
Running: which python3
/usr/bin/python3
Running: python3 -m pip install --upgrade pip
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: pip in /usr/lib/python3.9/site-packages (22.0.4)
Is there a way to set up some kind of virtual environment for python in a flatpak?
