VS Code broken?
Trying to install VS Code, and running into errors: Failed to install com.visualstudio.code: Error deploying: While trying to apply extra data: apply_extra script failed, exit status 256. What to do?
Anyone else getting this?
dad@localhost:~/Documents> flatpak install flathub com.visualstudio.code
Looking for matches…
Remote ‘flathub’ found in multiple installations:
   1) system
   2) user
Which do you want to use (0 to abort)? [0-2]: 1
com.visualstudio.code permissions:
    ipc                   network               pulseaudio                   ssh-auth       x11       devices       devel
    file access [1]       dbus access [2]       system dbus access [3]       tags [4]
    [1] host
    [2] com.canonical.AppMenu.Registrar, com.canonical.AppMenu.Registrar.*, org.freedesktop.Flatpak, org.freedesktop.Notifications, org.freedesktop.secrets
    [3] org.freedesktop.login1
    [4] proprietary
        ID                             Branch          Op          Remote          Download
 1. [✗] com.visualstudio.code          stable          i           flathub         108.7 MB / 114.7 MB
error: Failed to install com.visualstudio.code: Error deploying: While trying to apply extra data: apply_extra script failed, exit status 256
It seems to affect other people, you may want to subscribe to the issue in question:
apply_extra script failed · Issue #610 · flathub/com.visualstudio.code
