Under WAYLAND, the BLINK SIP application does not work properly, works partially, the Blink window is sometimes blinking / flickering and the icon of reduce close window does not appear so you have to guess where it is.
Otherwise, I tested with an SIP account I have, it works. Not tested yet with X window manager.
As a Flatpak alternative, for some people, Linphone is very good, Open Source and works great under Wayland.
Please report your issue regarding blink in https://github.com/flathub/com.icanblink.blink
D’accord, je vais le faire, merci Bilal. Allright, I’ll do that, thanks Bilal.
