I’m creating a flatpak manifest for dosbox-x and am running into a problem if I set the following permissions:
finish-args: # flatpak permissions
- --device=all # needed for gamepads and serial/parallel
- --share=ipc # needed for X11
- --share=network # needed for networking (NE2000, IPX)
- --socket=fallback-x11
- --socket=wayland
- --socket=pulseaudio
- --filesystem=home
If I than run the resulting program on Fedora 33 Beta running Wayland, the title bar and window controls are missing. To be clear, I am compiling dosbox-x in SDL2 mode.
When I run the binary outside flatpak, the titlebar and window controls are present.
If I change permissions as below, I do obviously get the missing decorations.
- --socket=x11
- --nosocket=wayland
