I know that sounds odd but where does mesa go? I just experimented a bit with some older mesa versions so the question came up.
I know that the apps go to .var/app/
and i also checked the filesystem that mentions
.local/share/flatpak/runtime
though that doesn’t exist for me. Our of curiosity where do these drivers and runtimes go?
~/.var/app
contains app data. It’s essentially the app’s home directory, and where XDG_*_HOME point.
The app itself is installed into the system (/var/lib/flatpak
) or user (~/.local/share/flatpak
) installation, into the app
subdir. There’s a bit more to it involving ostree and hardlinks, but that’s the simple answer.
Mesa is distributed as an extension, which is technically a kind of runtime, called org.freedesktop.Platform.GL.default
. You’re apparently using the system installation, so you can find it at /var/lib/flatpak/runtime/org.freedesktop.Platform.GL.default
This topic was automatically closed after 2 days. New replies are no longer allowed.
