Why are flathub downloads so slow? Can I work around?
I am physically located in Northern California, United States; not in the core Bay Area but on the coast north of there. When I look up the host that would be fielding my requests on ipinfo.io, I see it is in San Jose, CA. This should be reasonably fast; at least it should not be an order of magnitude slower than, say, Debian apt updates. But in fact, it is :frowning_face: Every monthly flatpak update is torture, multiple hours for sure. Any guess what’s up?
As a bonus question, if I can’t fix this, can I somehow download the updates in the background on a home server and then apply them on the desktop when ready? I should be able to install the flatpak client on the server, but the problem is communicating the state.
Ian
This would need a verbose log from your side, as connections vary from everywhere in the world. And GitHub · Where software is built would likely be the correct place to post them.
FWIW I’ve noticed the same. I’m in midwest USA and have a symmetric 1Gbps fiber connection, and flathub is consistently very slow. Typically killing and restarting flatpak install gives a decent chance of apparently hitting a faster mirror.
On the low end I’ll see 50KB/s (400Kbps) and if I get lucky, restarting the install process will give up to 50MB/s (400Mbps). That is a variance of 3 orders of magnitude!
The remote URL I’m using is https://dl.flathub.org/repo/, which resolves to a Fastly IP address. Presumably there are multiple mirrors configured as origins behind the Fastly service, and sometimes it picks a very slow one? Perhaps those slow mirrors should be removed until they can provide adequate service?
This is all guess work without logs
Distros usually offer a way to use a particular mirror, even if by default they connect to a CDN. Can flatpak do the same? I guess I feel that the limited control I have over the downloads adds to the frustration from the slowness :frowning:
If you’re not willing to provide actual logs, let’s start with the flatpak version?
@cdhowie you’re right! i’ve restarted the install a couple of times and went from 200kB/s to 5MB/s
