Zathura vim like minimalistic pdf, djvu, and more document viewer
Project information:
Homepage: pwmt.org
Info: Zathura – An Open Source Document Viewer for Linux
Download: pwmt.org
Download: djvu support version: pwmt.org
License:GNU open source.
Upstream has been contacted: Yes i send email i ask for permission to add flatpak version, but now i wait for answer. Email adress is in contact menu on download page. You can also try contact on irc channel. Look [Community & Contact] on Homepage (i cant add more then 3 link becouse im new user.)
Hi can anyone create Zathura flatpack, with all posible pdf and djvu, txt, support together.
Thanks. I rly love that apps.
Zathura is like vim minimalistic UI almost same shortcut for view document in meny format, grat for scans like pdf and djvu, old format with awesome scan compresion without lost quality. Also suport cbr and cbz probably comic compresion format.
I dont know when but i want say Thank You Zathura is on flathub :slight_smile: Thank You from the bottom of my hearts!
PS.My Question is if request is done i must tell someone about that, to close this subject? Or mark this as ended? I know Zathura Flatpak is here, but i not see any icon this request is done? Can anyone tell me i must ignore that, or now delete this subject?
Guys its me again, im 100% sure i install zathura from flatpak last time now when i search app on flathub nothing egsist :frowning:
I swear I saw it as well. It’s bothersome to have to rpm-ostree install zathura in fedora silverblue.
Hi. I reguest this app long ago, and im 100% sure i install it fiew time from flatpak, but now i rly dont know, im stupid, or lost mind… Thanks for answer Friend.
