Zoom on Fedora SliverBlue (Atomic desktop)
I’ve noted that the current Zoom flatpak fails if it’s allowed to run in the background. You’re best advised to amend the app settings accordingly.
I think it is good to report related issue tracker.
Thanks for the advice. I’ve done that now.
On reflection I realise this behaviour is probably because background-ing Zoom requires writing something to the OS layer, which can’t be done as that is read-only. If that’s so, the ‘fix’ would be just to turn off background running when using any immutable OS version.
